spta97 said:
Let me know how that works out - if I can avoid a trip to the dealer I'll do it. How did you determine it was from there? Mine really sounds like the power steering pulley but I could be wrong.
'99 XLT EB 5.0
I just listened to where it was and got lucky I guess. I used a long screwdriver and put the end on the pulley brackets and my ear on the handle. Did the same with the steering pulley.
Isn't the steering pulley ribbed? I wouldn't think it would chirp. it can't slip. If it was bad it would more like grind.
I changed the idler pulley (the one on top, right in the middle) and noise has gone away. To be sure I'll have to wait for a rainy day. Easy job, I suggest you give it a try, only $20 for the pulley.
All it takes is a 15mm ratchet and maybe a half hour. Not very hard to lossen the bolt either.
1. go under the car and release the belt tension with the tensioner, turning the ratchet clockwise but read the sticker on the grill for the direction of yours. Have someone slide the belt off the idler pulley. When you turn your ratchet, what you are doing is moving the tensioner to release the tension. You won't be lossening the bolt. The easiest way to get to it is from underneath. The irst pulley you'll see under there is a ribbed one, that's not it, that's another idler pulley. Just above that is the tensioner. It has a smooth pulley on it.
2. remove the bolt from the idler pulley up top and replace.
3. If you want to change the belt, snake it around but leave it off the idler pulley.
4. Go under car, released the belt tension and have someone above slide the belt under the idler pulley.
5. That's it.
Notes: There are 2 idler pulley's. The one up top that I replaced (smooth) and one down by the tensioner (ribbed). It also looked like the pulley on the tensioner is the same as the smooth idler pulley.
