tinner
- May 29, 2013
- KC MO. area
- 2013 Explorer Limited AWD
Unless they have moved it in newer modles, it is under the dash in an area above the parking brake. The fuse box is located just sightly up and to the left of the plug above the yellow sideways 'A' in the picture. And for more free info, the white sticker with the bar code shows your driver's side door code (changed to 0's for the pic).
Peter - Do you know if the turn signal / flasher relay is located there? Couldn't find anything in manual, dealers service writer said to bring it in and drop it off .
This might be part of the computer don't know. I the removed 2 relays in the engine compartment and the flashers kept flashing.
I'm going to do a LED turn swap and if hyper-flashing occurs, thought this would be easier to swap out flasher relay (if we have them} for one that's made for LEDs-non LEDs than doing resistors.
Thanks in advance, your knowledge of the Ex is always appreciated.
tinner
