24gtmaxx
- April 22, 2011
- little egg harbor,nj
- 1997 explorer sport
hi guys, yesterday, i pulled the motor from my 97 explorer sport, its the 4.0 sohc, heres what i found
on the front of the motor, the timing chain guide is broken in 4 peices
on the chain that goes thru the head to the cam on the driver side (facing motor left side), that guide is broken and loose in there
on the rear timing chain, all appears ok, but still changing it anyway
i set the motor to tdc, locked the crank with the crank locking tool, the cam for the rear timing chain lined up perfectly with the cam alignment tool
however, the other side (front timing chain) it seems to be out of alignment by a tooth.
how can i line it up without rotating the crank alittle to get the tool to bolt to the head and hold it without turning??
i ordered my kit, but want to be ready when it gets here, so id like to get it all lined up before i proceed
any advice is appreciated
this is my first post, ive been reading all i can about timing chain issues and replacment
this is a great site for info
