TM-oregon85
- March 8, 2012
- Oregon
- 1993 explorer
Now i see you have 36s
So you have the 4 speed and 4.88 what size tires and what rpm are you at doing 60?
You really think im not going to like 4.56? I just dont want to go to far. I have a car to but i like to drive the X. Id like it be street friendly and like i said im going to run 33s for like 2 years or more. So now i want to set it up for the 33s.
I've got 4.56 and 35's and it's manageable. It's not going to win any races, and I'm running just over 2000 rpm at 60 mph.
If I was to do it again would I go to 4.88s (or even 5.13)? Yes, but not for reasons of acceleration of highway driving etc. It would be for the lower range when off-road.
There's tons of recommendation about which gears go best with which tires size etc. You just have to pick for yourself what is most important to you. Lower gearing, better acceleration or lower highway rpm
Curious: you guys consider torque multiplication when it comes to comparing automatic vs manual transmissions?
Well, on regular roads and such, an automatic transmission (the torque converter) multiplies engine torque before it enters the coupling phase which might negate the need for say 5.13 over 4.88.What do you mean?
I would say thats backwards.i know in theory thats true. Ive driven both a 5 speed and auto both with 33s and 3.73 and the 5 speed had way more power.i think it has to do with more of the power loss of an auto compared to a 5 speed.also the a4ld is a pos so the lower gear you can handle the less strain its going to be put on it and lower temps.im going to a 2.9 5 speed with the lower first gear to help with tq and power(also because the a4 wont handle the power im putting down now)
Do you no if the 2.9s 5 speed would help lower RPMs going 60 over the a4 or just a lower 1st?
Do you no how much HP TQ you have and how much psi?
My rig had the skyjacker radius arm crossmember with the bronco arms. Just used the 7° C-bushings for caster and had the passenger side arm wristed. It works perfect.
