Id like to be able to run 35s down the road plus i think its going to be less work in the long run. The d44 lets me have more flex less moving parts less problems with alignment tires last longer and more ground clearance. Right?
Maybe... Maybe not.
I've had 35s on mine for over 7 years now, and I
use it too (just look at my BII Cardomain link).
I have Skyjacker Cherokee XJ/ZJ springs, longer shocks on extended shock towers and extended radius arms. Nothing else under there is really anything special aside from a limit cable I put over the frame to keep the hood down on climbs, which forces a bit more flex out of it at the same time (same effect as hooking your winch or something to the center of a straight axle).
I also got rid of the crappy misaligned stock steering linkage as well.
Never had an issue with tires wearing out or stuff breaking, goes everywhere I've needed it to.
Now if you start putting ill-engineered liftkit junk onto it (stiffassed coil springs and a drop pitman arm that doesn't match with the lift leaving the steering linkage all out of whack), then sure, you're bound to have some issues. There are easier ways to steer around those issues (so to speak lol) than a SAS, so that's why we're suggesting sticking with what you have. Then when you get real serious about it, you can dive straight in for the good stuff (a D60 with a 10.25" rear) without already having a bunch of $$$ tied up into the moneypit of a D44.
Also keep in mind, ANY new (used) axle you get is also likely to need a bunch of work too, chances are you'll still be spending some $$$ to get everything ready whether you put it into your D35 or some other axle. At least you should already know what it is your D35 needs... Anything else will be an unknown.
Not really.depends on type of 4x4ing.i dont know why people dont like the d35.the d35 can be stronger than a stock d44 when upgraded and cheaper
You said it later in your post, but I thought I'd FIFY just for clarity
An upgraded D44 will certainly be stronger than the D35, however upgrades on a D44 don't come cheap (pushing toward the cost of getting a D60), so you'd have to weigh that carefully against getting the better axle that'll still have room to grow, if needed.
