Betty Boo
- October 23, 2007
- Derbyshire, England.
- 99 North Face UK Spec
Hi Everyone,
Just wondered if you have LPG (Liquid petroleum gas or Autogas) in the US to run your cars on?
We have had it for a while and its price is about half that of ordinary petrol but you obviously need to get your vehicle converted to run on it- usually it costs from £1,500 to get it done professionally.
My Explorer was converted when I bought it and you don't hardly notice any difference in performance when using it, a slight lack of acceleration but not much. The tank is in the spare wheel well under the boot floor and you really need to had an additive put in with the lpg gas to stop the head getting damaged as i believe that the lpg burns hotter? or something like that, mine has an auto dosing system for flashlube as part of the conversion though so I just have to keep it topped up.
What is LPG?
Liquefied Petroleum Gas (LPG)
Liquefied Petroleum Gas (LPG) is a natural hydrocarbon fuel made up of propane and butane. It has the special property of becoming liquid when under pressure, and reverting to gases at atmospheric pressure. This means it can be easily and conveniently stored as a liquid – a big advantage over natural gas, which will only turn to liquid at extremely low temperatures. What’s more, LPG is 250 times denser as a liquid than as a gas mix. So, a lot of fuel can be stored in a relatively small space, for use almost anywhere. Have a look at ‘About LPG’ on the LP Gas Association website www.lpga.co.uk for more information on LPG’s chemical make-up and safe handling.
Where does it come from?
About 60% of the world supply of LPG comes from the separation of natural gas products, and 40% is a by-product from the refining of crude oil. In the past, LPG has been considered as waste and flared off; now it is recognised as a major energy source. It is produced in vast quantities (the UK produced 6.8 million tonnes in 2003) and exported over 3 million tonnes. It is particularly abundant in the North Sea’s ‘wet’ crude oil and offers security of fuel supply for many years.
What is it used for?
LPG has several applications: domestic or agricultural heating, when there is no natural gas pipeline nearby; chemical or refinery operations; and vehicle fuel, when it is often referred to as Autogas. If you want to find out more on LPG uses, information is available from the LP Gas Association - see www.lpga.co.uk.
LPG is:
safe
readily available
portable and flexible
efficient and reliable
We can buy it at most petrol stations in the UK and it quite easy to get in Europe as well. It really seems to be the way forward here at the moment and allows us to afford to run our cars as we are now paying approx $9.30 per gallon of standard unleaded petrol!!!
What is LPG?
LPG is:
safe
readily available
