injectors | Ford Explorer Forums - Serious Explorations
injectors
foxy
lobethal south australia australia
9/99xlt ur
Peoples, With the higher and higher price of fuel ulp & pulp is there available anywhere multi purpose fuel injectors using both fuels plus LPG ? I know lpg is difficult if not impossible to use in the explorers because of the manifold now ,is there an injector for the exlporers that is able to use LPG (liquid petroleum gas) I believe it needs to be an injector because to have the inflow just prior the inlet in the manifold could cause problems is this so or not
I think this post needs to be moved to another forum.
Can a regular explorer engine even run on LPG?? And yes, you might want to try the "UNDER THE HOOD" section next time...
sorry guys I realised straight after I posted I was wrong
