hal_94
- August 3, 2004
- Providence, RI
- 94 Limited
It's just been one of those days--the quick question is: how on earth do I get the clip holding the front rubber brake hose piece to the top bracket loose? I've disconnected the brake line at the top where it goes through the brakcet where the coil spring sits, but can't get the clip off to remove the hose piece. It's awfully cramped, the best I can do is just get it to spin around.....
Thanks....
If you wanna know why it's "been one of those days"....
I went to replace the brake pads, realized that one of the calipers was sticking. Since I had intended on replacing the front brake hoses at some point in the near future anyway (they are cracking), I figured what the hell, might as well bleed it one time instead of twice and do it all at once.
So, I put it all back together, went and got the parts, came back and realized that the shop had gotten the lug nuts on so tight on the driver side that I couldnt get them off (had gone in for some work a while ago). After nearly rounding off one lug nut, I took it to get the shop to loosen it for me. Came back, got it all taken apart (except for the above problem) and then the heavens opened up and I got drenched....
Anyway, it looks like its clearing up, so I guess I can go take another crack at it...
-Adam
Thanks....
-Adam
