SailorKane
- December 28, 2009
- Tampa, FL
- Explorer '97 4x2
Newbee to this forum. I have a '97 5.0 V8. We were out of the country and it sat in the garage for 6 years and the fuel pump died. We just replaced the fuel pump, put 5 gallons of new gas and a can of techron in the nearly-empty tank, and now it starts just fine. I also replaced the fuel filter. It idles just great. When I run it around the block, sometimes it accelerates just fine, other times it'll only run at idle and any push of the pedal causes it to bog down and even stall.
But I'm sure the fuel system is full of crud from old gas. My question is: is it likely that the techron will eventually clean out the system? Or do I need to take more radical steps and actually clean out the system myself? If so, how?
