2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
For ease of reference this page contains the latest fuel economy results and associated vehicle configuration. Please note that Upstate South Carolina is fairly hilly for both city and highway driving. Highway mileage is based on a 100 mile round trip between Greenville and Gaffney maintaining posted speed limits using cruise control. Approximately 20 of the 100 miles is boulevard/city driving.
Fuel Economy Results - Goal 20 mpg city
87 octane unleaded regular with up to 10% ethanol
City driving: 16.4 mpg
Highway driving: 23.0 mpg
Associated Configuration
Body: 3900 lbs with full tank & spare tire, no driver, side steps removed
Tires: BFG P235/75R15XL Long Trail TA Tour @35psi
Suspension: front lowered 0.75 inch via torsion bars, rear lowered 0.75 inch by replacing monoleaf springs with 3+1 leaf springs, Edelbrock IAS lowering shocks
Rear axle: 3.73:1 open differential with Super Tech 75W140 synthetic lubricant
Induction: Spectre cone air filter with 4 inch dia. outlet drawing air from engine compartment, Lightning 90 mm MAF sensor, 4 inch to 3 inch dia. 45 deg angle silicone hose, 75 mm ported and polished Ford non-production racing throttle body, 75 to 65 mm throttle body outlet to intake manifold inlet adapter, 00M12 kit, AutoMeter 5978 wideband air/fuel ratio meter
Exhaust: Stock
4.0L SOHC V6: Stock
Ignition: Champion 4401 Truck Plugs alloy electrodes with 0.056 in gap, original stock plug wires
PCM: Custom tune for engine performance and shifting by Henson Performance
Engine oil: Super Tech full synthetic 5W30, remote Mobil 1 full flow filter (M1-301), remote Amsoil bypass filter (EABP90), thermostatically controlled (215 deg F) external 6 pass cooler, Accusump
Engine coolant: 2 row radiator, 195 degree thermostat
5R55E: Mercon V ATF, remote Mobil 1 full flow filter (M1-301), radiator & dual external coolers, valve body bonded separator plate/gasket and improved solenoid bracket, reverse servo D ring gaskets
Introduction
The increase in fuel prices and the warming of the weather has prompted me to investigate ways to improve my fuel economy. My 2000 Explorer Sport got 14.5 mpg on my last tank of gas which was all city driving. This compares with 19.5 mpg (also totally city) for our stock 2006 Toyota Highlander with a V6 engine. Even though the 2011/2012 winter has been fairly mild here in Greenville, SC I suspect my fuel economy has suffered due to running the engine while scraping ice off the windows. That's one disadvantage of keeping the vehicle outside.
Just prior to my latest tank fill I completed my third and final engine flush and oil and filter change. Hopefully, most of the sludge has been removed from the engine so I am again using full synthetic oil. The synthetic engine oil should improve my fuel economy on the next tank. I have full synthetic oil in the rear axle (2WD vehicle). I could switch from Mercon V to full synthetic in the 5R55E but I doubt that the cost is warranted at this time.
One thing I realized is the A/C compressor engages when defrost is selected. I understand that A/C helps clear the windshield by removing moisture in the air but I'm going to investigate a method to disable the A/C. As I recall my 1950 and 1956 Oldsmobiles had no A/C and the defroster seemed to work OK.
Exhaust: Stock
4.0L SOHC V6: Stock
Introduction
