coco944x4s
- October 25, 2009
- Staley, NC
- 94 Explorer 78 F150
Ok, first of all I know this has been covered, and i have searched until my head hurts from information I have read. I decided the best thing I could do to better understand what I want to know is just to post my plan for rebuilding a 4.0 OHV.
This is what I know that I will use:
Block: 91-94 block, prefer 94, thinking 0.020-0.040 overbore
Heads: 95TM, port/gasket matched, stainless valves if money allows
Cam: Comp Cams 410 cam, looking for more low end power as I tend not to race, but rather pull more since my Ex is for 4x4 and utility uses, not racing, also to keep stock length push rods and single springs
Exhaust: probably gonna keep my stock manifolds and y-pipe unless i can find a good deal on some headers, already have big pipe after the convertor into a flowmaster one chamber single in/dual out
Intake: port/gasket matched 91-94 upper and lower
I do not know however, if I should keep my factory injectors, replace with OEM, or replace with aftermarket higher rated injectors. Also, I'm going to stay with 94 style pistons to keep the boosted compression ratio with the 95 TM heads, but which manufacturer should I go with? Should I just stay with a 0.020 overbore, or go as high as I can find pistons for?
I am not new to rebuilding, I have a 2.9 at my parents on a stand with a 0.060 overbore and fully ported heads waiting on a camshaft manufacturer to tell me if they will grind me a cam or not. I just would like those who have rebuilt a 4.0 and have experience to weight in and give me some advice on what works and what doesn't. I know that I will catch crap for not doing a 422 cam, but I think the 410 will fit my needs and driving style better.
Let me know what you think.
