I've been thinking about some serious lighting... 4 100w lights up on the roof, and 4 100w lights in front?.. Eh eh?.. So could the alternator handle it considering that dude up there has like an 800w amp??? Is the math still the same?
800w/12v=66.6amps
OK Storlied, I'll say something, even though this is 2000limitedx's thread.
First any load over the stock electrical systems in a vehicle is overloading the latest systems but a certain amount is doable.
To answer your question the best I can NO, Not a Chance... unless your alternator is a HD 130 amp setup.
Put on teh setup you want for lights, set them up using four circuits, use them as you like watching where the volts meter goes as you turn them on.
If the stock alternator holds up and the voltage remains at 14+ volts then it may work out if not start replacing; battery last.
My basic rule of thumb is, two lights per relay, so if you have 2 x 100 watts = 200 watts - 17 amps per pair of lights.
So for each pair of 100 watt lights you will need one 30 amp automotive relay with four pins, numbered 30, 85, 86, and 87.
Note: Stay away from the relay with 87a contacts, mainly because when the circuit is off pin 87a will be live, that is unless you have a need for it.
That will be four relays for you storlied... how you switch these relay is up to you, four switches each switch controlling a set of lights or two switches or even one but the more switches the more control of the lighting you have.
IMHO, 17 amps/pair is too much for 16 ga wire and 14 ga will handle 15 amps safely but 12 ga would be my choice, it will handle 20 + amps so the fused power wire from the battery to pin 30 and then from pin 87 to the lights needs to be 12 gauge wire and fused for 20/25 amps.
IMHO this is the basic safety setup, no overloading of the circuits, extra circuits to make sure if one goes out the others will still work and get you home.
Are there other ways to do this hook up, yes, but this is my way. Extra circuits and oversized wire makes for the best all around setups.
Luck,
