captaineric
- February 12, 2004
- Bellingham, Washington
- 1992 Sport
Have a Jasper rebuilt engine in my '92 Sport and the mileage is lousy, around 13 or so (was around 15 when the engine was new but has dropped over the past several thousand miles). Checked the fuel pressure regulator and pressure is fine at 34 psi with no sign of leakage into the vacuum line. However, pressure drops to 0 immediately after shutdown. But, engine always starts right up if I turn the key on until I hear the fuel pump stop running before cranking. No CEL's noticed. Want to change the O2 sensor but looks like a ***** to get to the plug connector on the back of the engine block. Any suggestions? Have ordered a new FPR since I have the original and figure it's time to change it regardless of the gauge readings. Any other ideas? Engine runs great! Good power, no hesitation, smooth idle.
