Docholiday93065
- February 17, 2016
- Los Angeles
- 2000 Ford Exlorer
My mom's arthritis has gotten so bad that she is unable to turn the key from the "Run" position to start the car. I am thinking of adding a push button momentary switch so all she will have to do is position the key to the "Run" position and then push the button.
I searched here on this site and found the "bulldogsecurity" site for access to the wire diagram which appears to be the Red/Blue wire for starting only one wire?
The rest of the search findings showed either bypass ignition key completely or some other method. What I want to do is preserve the original operation of the key/ignition switch with the option of either using the key itself to start the car or by just using the key to its "Run" postion and pushing the button.
What is missing, is that where is this red/blue wire (easy Location) and how should I wire it? Are two wires need for start?
Thank You...
Thank You...
