Ive got a 2002 Ex. The light under the passenger side rear view mirror isnt working. Im guessing the bulb is blown? How do i change it out?
It might not be the bulb. It could be a broken wire:
I had similar electrical issues with my 02 xlt. The dome lights would stay on until the battery saver feature turned them off,
the driver side puddle light didn't work, the keypad on the door would set off the alarm when I pressed it, the door ajar light would flash and beep at highway speeds, the radio would shut off as soon as I turned the key off, etc. Most recently all 4 windows stopped working.
A lot of electrical issues can be traced back to broken/damaged wire(s) in the boot between the body and the driver's door. I found 2 broken wires and repaired them. The thin black ground wire was broken and after repairing it all was back to normal. When the windows stopped working, I repaired the thick black ground wire and the windows now work like a champ.
Here is the thread for removing the door panel:
http://www.explorerforum.com/forums//showthread.php?t=303524
Here is a great thread for checking for broken/damaged wires, thanks to
synyster for this awesome write-up:
http://www.explorerforum.com/forums//showthread.php?t=270081
Be sure to take your time when looking for broken/damaged wire(s). Check all the wires for breaks/damage. When you think you're done looking, look again, and again, and again. A bright flashlight can be very helpful.
Check out this thread for changing the bulb in the puddle light:
http://www.explorerforum.com/forums/showthread.php?t=293306
Hope this helps out! :biggthump
