Rhr power window | Ford Explorer Forums - Serious Explorations
Rhr power window
Fettler
Melbourne, Victoria
The RH rear power window in my 05 has been working intermittently. Today it is not working at all and neither the driver door module or its own door window switch works. Is there a central relay system or is it just through the switches? Any ideas.
Pull the door panel and test for power at the motor.
I pulled the trim off and I have voltage at the motor connector. The motor seems warm after a few tries so perhaps the window mechanism is jammed?
