Ok... deep breath... I am going to repeat what I said in Stage 1 so that those thinking that $180-190 is "acceptable", I just shudder and want to puke, thinking about it...
1. ANYTHING with an open filter in the engine bay is NOT a Cold Air Intake. Its a HOT air intake. I don't car if K&N has a heat shield. If it is not ISOLATED from the under hood temps and/or Fan wash, its a poor design.
2. The Restriction in both the 4.0 & the 4.6L engines is NOT the air box, the filter or the location. It is the rubber/plastic, corrugated tubing and silencer on the side of it. Think of free flowing exhaust, eliminate bends, restrictions = more flow. Common sense. The tract from the MAF side of the 4.0 & 4.6 engines AFTER the MAF is where the losses are. PERIOD. A good, fresh filter, and a clean ducting from the MAF = success.
3. "Seat of the pants" dyno's are mental dynos. They TELL you your $180 spent was worth it. I have a scan gauge and I can look at Air intake temps (IAT), as well as other ECM values. Stock air-box + good ducting = 15-30 degrees lower IAT's and my wife's Monty runs within 5* of outside temps at all times. The restriction adds turbulence which adds heat.
4. MPG up 3 MPG. End of conversation, before the original engine let go of (2) bearings.
5. Cold Air Intakes are a MARKETING ploy to TAKE your money. Volant is the ONLY Truck/SUV manufacturer that makes CAI's... PERIOD.
Sorry for the Rant , but y'all gotta THINK about the dynamics and the systems you are modifying and see where the gains can really be.
Go back to roughly page 3 of this post. Posts #63-70... READ... look at the $$ vs what you want to spend on a Hot Air sucking waste of Money...
Sorry... stepping off my Logic Soap Box now.
Rob
