- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
Okay, accepting that it is a 99 trans harness, check the engine harness too. Disconnect it and locate pins 30 and 33. The later harness will have no wires in those locations.
I'd say that the 1996/97 computer needs a ground at the #33 pin, and the pin 30 octane adjust shorting bar input circuit is probably needed also. The examples of other pre 1998 Explorers with later 4R70W's in them(with 96/97 PCM) likely have the 96/97 wiring harnesses, so they have those two circuits.
