- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
I found something which should be very helpful for anyone swapping the Explorer 302 system into anything else.
Below is the 134th post from ttbit's thread I used a 99 motor/donor, not a 96. Maybe this will help explain things...(copied from another forum)
2001 rangers had one more operation that was performed in the PCM that the explorers had a separate module for; the conditioning of the VSS signal.
In the ranger, an OSS signal from the transmission was sent to the PCM, the PCM then in turn used this for determining shift points and broadcast a conditioned version to the cruise control, speedometer, ABS, etc.
In the explorer, the VSS signal from the rear axle is sent to the ABS module. The ABS module is then used to condition the signal and broadcast a the conditioned signal to the cruise control, speedometer, and PCM for determining shift points. One additional feature the explorer has is a “G-Force Transducer” that measures how hard you are breaking for the ABS.
Because we are using the PCM from the explorer, it will require a conditioned VSS, This requires using the explorer ABS module and “G-Force Transducer”.
Not using these components will not stop the vehicle from running, but the speedo/tach will not work and the transmission will be running in “limp mode” because shift point can’t be optimized based on vehicle speed. The lack of this signal also makes the engine throw a code and the check engine light comes on.
I'm quite sure the tracs are the same way...[/QUOTE]
