donlightbody
- January 20, 2009
- co
- 2003 XLT
I've had this '95 ex for a bout 2 months now and still unfamilar with the front axle. Am used to my 88 BII manual hubs. So I noticed lastnight with the front wheels off that the axle shafts are turning when I spin the rotor, dash switch on 2wd and tcase not engaged. In the manual setup I know this isn't good. Looking through the chiltons I came across "vacuum disconnect axle lock." So I'm guessing this behavior is not normal for this truck. Am I correct? And does this sound like to place to look? It does seem like there is the possibility it locks in inside toward the diff and it is correct? Just confusing myself now... So, are the axle shafts supposed to spin with the wheels in 2wd? if not, is this the place to start? Thanks. hope I didn't confuse anyone as much as I did myself. :exp: wow it's late.
