- June 16, 2003
- Humboldt, KS
- 2000 Mounty
OK in a pinch and I don't do it this way myself I use a gauge . you can do this, pull the oil pressure sender and make SURE it won't start have some one bump it over or crank it over for a few seconds and see if oil squirts out of the sender hole ..it will make it bit of a mess but.. Personally i would make the light work and then go from there. Not a big money fix use a light bulb for a temp oil "light"..just to see if the sender works
Ah, but what if his gauge is not lying? He tested the switch running and not and no change in resistance--since the sender is just a switch it should have.
