Well so far im about 2000$ into the swap but things are going very well. Ive just finished putting my fornt axle together minus the locker. Im going to hold out and find a used ARB or wait until i can get the same Electric locker front and rear. Here are some pic's of the axle.
Not all the $$ is into the axle some of is in the hydro assist steering and the onboard air system going on.
I know its not the biggest axle but it will do what i want it to. After the Chromoly Axle shafts it should be done.
This way i keep my abs up front, HP, same bolt patern as rear just what i wanted. Still waiting on some other fab parts but ill keep you guys updated.
High Pinion Dana 30 from a 93 Jeep XJ with 4.88 gears
new 760x u joints, ABS, Sloted Rotors, New Calipers, Ceramix Pads, Billet axle seals.
