tyqchur said:
I have a 1997 Explorer Sport 4.0L 72,000 miles that has a intermittent missfire. A code was set for "cylinder 4 missfire" . I investigated with a scan tool and noticed that both Short Term Fuel Trim and Long Term Fuel Trim were displaying a static -100%. Additionally the vehicle speed displayed 0 at test drive. The scan tool was connected to my 2000 Mustang and it operated properly showing varing values of Short and Lonf Term Fuel Trim and vehicle speed.
Any ideas why the fuel trim table appears to be without useful data? Is the PCM shot or should I start to look at the MAF/O2 sensor.
When the scanner starts seeing the PCM data stream showing 100% fuel trim on both short and long terms, it is a sign that something else is amiss in your PCM circuit. The fuel trims are computer compensated for other variable factors on your truck, such as a dirty air filter, bad O2 sensors, plugged cats, bad wires, etc. What happens first is the PCM will compensate fuel flow to try to hit the proper air/fuel ratio via the oxygen sensor input with the short term trim value. When that hits (and stays) at approximately 50% the long term trim will begin adjusting (learning) to bring the short term trim back to center. (Think of the trims as a pair of scales, from 100 - 0 - 100, with 0 being centered, and perfect.) As the short term trip continues to compensate for whatever is amiss in the engine control system, the long term trip will continue to move to the end of the scale. When neither it, nor the short term trim can compensate, the engine will start to run rough (or rougher as the case may be).
I'd start in my diagnosis of this problem in a couple of ways...
1. Figure out what is causing the mis-fire on #4. It can only be a couple of things -- bad injector (or plugged fuel rail), bad plug or wire (or coil), or an intake leak -- presuming that all else is good mechanically. (Some times a mis-fire on one cylinder will also prompt codes on the next cylinders to fire, as the mis-fire code is set via crankshaft counts, and one cyl. affects the next couple in order with decreasing counts in the next couple.)
2. Check the air cleaner and MAF. Clean both.
3. Check for oxy sensor function. Make sure that they are responding when you blip the throttle and are not out of specs. (Note well that an out of spec oxy sensor is not necessarily a bad sensor! It may be reading perfectly, but out of specs from some other issue. Don't believe the Zone when they read your codes and automatically sell you a sensor!) The back oxy sensors should be flatlined once the cats are at operating temps. The front ones will continue to respond to engine load and fuel compensation.
4. Check for intake leaks. A couple ways to do that... Use a propane feed (a small volume of propane is shot around the intake and vacuum line ports while watching the scanner and/or lab scope -- look for rpm rise, and/or cylinder fluctuation) or use starting fluid judiciously (
PLEASE don't just hose down the engine compartment! That stuff can and will burn your truck to the ground!) A small shot in the expected trouble areas can pinpoint problems when the engine revs up from an intake or vacuum line drawing the fluid into the combustion chamber.
5. Check plugs, wires, etc., also.
This should allow you to pinpoint the problem/s.
