dougiiefreshh
- October 19, 2006
- 2003 Ford Explorer
i was curious on how to change the rear end fluid? can someone tell me the steps...
I don't have the service CD on this computer, but having just been underneath mine, I can tell you with good certainty how to do it.
I filled mine with Amsoil Sever Gear 75W-140 synthetic oil and 4oz of the friction modifier as I have a D4 limited slip diff. My rear end is quiet and smooth and hopefully I won't have to think about for several years now.
Rumple
When I had my axle out, I didn't see a clutch spring inside the diff... or at least didn't see it thru the axle hole. Do you know what codes to look for, and where they are located, that indicate if the truck has a limited slip diff?
Mine is 4wd. I have heard that not all 4wd's have a posi in the rear, but how could that even be?
I have an '01 Explorer, should I change my rear diff fluid? What happens if I don't?
It's a good maintenance practice to change the rear end fluid. So yes I would recommend that you change it. However since '97 Ford has considered all rear ends "lubed for life" and has stated that there is no need to change the oil unless it is contaminated. Dumb idea IMO. But you probably won't have any problems if you decide not to change it.
