Jbrobeck
- July 7, 2005
- Centerville, MN
- '00 Mountaineer Monterey
Alright, I have spent the last hour searching the differences behind all these Ford stereo's and only became more confused.
What I know as of right now:
I have a 2000 mountaineer with the CD/Tape player with RDS and a factory sub.
This is the stereo with the infamous Display problem (mine works fine as of right now)
I do not have a cd changer, but have the plug/ controls if I desire to install one
I have steering wheel controls and rear console controls
What I am trying to accomplish:
I LOVE THE LOOK of the factory Head Unit, and the functionality of the steering wheel and Rear console controls, and DO NOT WANT TO REPLACE THEM.
However, I would like to improve the sound quality and add a little more bass, I would like to do this by replacing the factory speakers and sub, and drive them with 2 new amps (one 4 channel and one Mono) but..... I know that if the stock head unit has an internal amp with a distortion as high as whats been stated (~10%) I don't dare try to add an aftermarket amp on as it will sound like crap!
<<<<<<EDITED>>>>>>
What I need to know:
This is the info I got from the Sticky:
Audiophile Systems are rated at 145 Watts RMS @ 2% THD (4X15W from the head unit or remote Parametric Amp; 1X85W from the SW Amp) Audiophile Systems have an Advertised Peak Power rating of 290 Watts
Now this is showing 2% THD from the head unit to the 4 speakers without running through an external amp, I should be able to hook this up to a 4 channel amp with good results shouldn't I?
And, I should be able to just remove the factory amp/sub and replace them with an aftermarket setup correct? (wiring aside)
Thanks in advance for the help.
Josh
<<<<<<EDITED>>>>>>
Josh
