rousheldon99
- September 25, 2005
- Charlotte, NC
- '00 Limited
Alright, so I have been having some issues with sohc not idling be it in cold weather or warm. It starts fine, but then immediately dies. It also will die if I am riding down the road and don't give it enough gas to keep it around 1000 rpm . It was giving me a check engine light so I had it checked at advance and it came up with Cylinder 3 misfire as well as p1506 which was the iac over speed. That propted me to change the iac as I have heard that is a common problem with these things and it did nothing whatsoever to help.
The only other pertinent info I can think of is that when it is running I can definitely feel it misfiring on a consistent basis when it under load.
I was thinking vacuum leak somewhere, but I had the 00m12 recall done on it around 60,000 miles although it does now have 140,000 on it. My only other thought was that it could be a fuel delivery issue to that cylinder perhaps.
Any thoughts or ideas would be appreciated, this is really starting to drive me nuts.
Thanks a lot
Thanks a lot
