L2rocku2
- May 5, 2007
- Chandler, Arizona 85224
- 2000 E/B AWD 5.0
Hello All
As far back as I can remember, the idle has always seemed a bit high. Cold start up around 1500 +/- Warm idle 1000-1100 +/-
Bought her new for wife & it's been her daily driver since. I'm doing a complete tune up and remembered the high idle, so I took a closer look.
When engine is @ operating temp and you UNplug the IAC, shouldn't the engine run rough, if not stall?? When I unpug the IAC, idle drops down to 600-700 rpm's and runs smooth as silk :scratch:
Possible that the IAC needs to be cleaned/replaced??
Just turned 71,000 miles.Doing/done= Sea-foam, plugs, pvc, ALL coolant lines/hoses, cleaned maf & TB, vacuum hoses.
Any thoughts on this would be appreciated
