ORDarksideD
- March 24, 2010
- Oak Ridge, TN
- 2001 Explorer Sport
I recently purchased a 2001 Explorer Sport with 45,000 miles(Checked via Carfax and the title). I've discovered a few problems with it. Any help will be greatly appreciated.
1. When starting, it will only "click" and not turn over unless you turn the key to the OFF and ON position a few times, before attempting to start it(when doing this I can hear a noise coming from the engine. I assume it's the fuel pump making the noise, but could be wrong) and then giving it gas while starting it.. It also seems to idle slightly rough(around 1500 rpm and then will settle at about 1000 or so rpm after a few minutes). I had the battery tested at Advanced Auto and was told that it was in good condition(even though it appears to be the original battery) and that he thought I probably just needed to replace the fuel filter. Does this sound like the case or should I go in another direction?
2. After the first time I filled it up the "Check Fuel Cap" and "Check Engine" light have been on. I've also noticed that gas gauge will go up and down.
3. When engaging 4x4 I turn it to the "4X4 High" setting and hear a click and the "4X4 High" light turns orange on the dashboard. I then switch to "4X4 Low" and hear nothing and the "4X4 Low" light does not come on. I'm unsure if the low setting is not working or if the light just doesn't come on.
I also have a list of parts that have been replaced and what year they were replaced:
EGR/DPFE Feedback Sensor Replaced - 2002
EGR Feedback Control Solenoid Replaced - 2002
Engine/Powertrain Computer/Module Replaced - 2002
Transmission Shift Solenoids Replaced - 2002
I'm not sure if these are all separate problems or if they are connected somehow, but any help will be greatly appreciated. Thanks.
- Josh
- Josh
