Y2K Explorer
- December 8, 2015
- Behind the Wheel/On-Da-Road
- 01 Explr Sport 2-Door 4x4
Truck Info:
2001 Explorer Sport 2-Door Version
4x4
Stock
100K+ miles
Not the orginal owner/little-to-no history
All headlights/signals/brake-lights operate
Overdrive button functions & dash lights up normally
All dash lights function at start-up & when "running"
So I have been searching all over because I'm have electric/electronic issues and list them individually:
1- The 4x2/4x4 selector switch won't shift the truck back & forth from 4x2 to 4x4 and back. Also at night, the glow/illumination does not light up above the switch.
I do not see the light in the dash changing [from 4x2 to 4x4] when operating the selector switch.
2- The rear wiper won't operate but when you push the button in, the fluid motor operates. Again at night no illumination above this switch.
3- The OEM CD player quit working all together [No FM No CD] but will illuminate when I turn on the headlights. When you disconnect the deck from the wire harness' and plug them both in, the CD motor operates like normal- as if either ejecting or cycling "searching" for a disk then stops.
4- The overhead counsel lights do not operate at all but I tried installing LEDs but found the copper strips are worn & probably broken inside the plastic tape. Guessing this will need the entire overhead assembly replaced. I do get the temp display & changes as operate the light switch.
I went thru ALL the fuses [under the hood & driver panel], found a couple of the tiny ones "burnt" out. So replaced them.
Reading into this issue, the GEM module may be the culprit [In the dash on the left-hand side next the OE radio]. Okay, thinking simple enough, but my specific one is discontinued & ZERO luck on eBay. FYI- sticker # YL2Z-14B205-BA
But at the bottom of the sticker, it says 4x2!!!
Does this mean someone at some point replaced the GEM module with the wrong one?
I found these based on my eBay search:
XL2Z-14B205-BB
XL2T-14B205-CD
XL2T-14B205-CC
XL2T-14B205-CB
Being the one in my Explorer is discontinued, do I chance it & try one of these GEM modules but the ones with the "4x4" labeled at the bottom???
Based on the eBay pics, these are the exact shell with exact same connection & mounting points too. But different part #'s & each of the individual listing/seller all state theirs came out of 2001 Ford Explorer...."And Tested" with the donor vehicle....
4x4
Stock
100K+ miles
XL2Z-14B205-BB
XL2T-14B205-CD
XL2T-14B205-CC
XL2T-14B205-CB
