01 sport trac need info on tt spec | Ford Explorer Forums
stang7tl
The FLA
01 explorer sport trac
i want to know if anyone knows what is the factory spec for the torsion bars the distance for the center of the wheel to the body? and i cranked on mine to level out the truck and then after driving 30 miles i checked it and they are sitting back in the spot before any help?
when you adjust you're ride height, make sure you bounce the suspension a couple of times before measuring the adjustment. the torsion bar is a spring, and you want to make sure it zeros out....also any adjustments sould be make while the weight on the vehicle is off of the suspension...
