here this should help i used to work for ford heres what ford says to do....
SECTION 308-07A: Four-Wheel Drive Systems 2001 Explorer Sport/Sport Trac Workshop Manual
DIAGNOSIS AND TESTING Procedure revision date: 01/07/2002
Four-Wheel Drive Systems —Electronic Shift
Refer to Wiring Diagrams Section 308-07A for schematic and connector information.
Special Tool(s) 73III Automotive Meter
105-R0057 or equivalent
Worldwide Diagnostic System (WDS)
418-F224
New Generation STAR (NGS) Tester
418-F052 or equivalent scan tool
Principles of Operation
Transfer Case — Electronic Shift
The four-wheel drive electronic shift-on-the-fly feature electrically shifts the vehicle transfer case between 2WD, 4WD HIGH, and 4WD LOW. The system mode is selected by the operator through the mode select switch (MSS) on the instrument panel. The operator is informed which mode the system is in by two instrument cluster indicators, one for 4WD HIGH which appears as 4WD HIGH, and one for 4WD LOW, which appears as 4WD LOW. Shifts into 4WD HIGH can be made at any speed. When shifting into 4WD HIGH with the vehicle stationary, tooth blockage may occur preventing shift completion. When the vehicle is driven above 8 km/h (5 mph) the shift will complete. When shifting in or out of 4WD LOW, the four-wheel drive (4WD) control module requires that the vehicle speed be less than 5 km/h (3 mph), the brake pedal be applied, and the transmission be in NEUTRAL .
The gearmotor encoder assembly is mounted externally on the transfer case. It drives a rotary cam which moves the mode fork and range fork within the transfer case between the 4WD HIGH, 4WD LOW, and 2WD range positions.
The four-wheel drive (4WD) control module controls the shift motor encoder assembly that shifts between 4WD HIGH, 4WD LOW, and 2WD modes.
The 4WD control module accomplishes shifts by interpreting inputs from the following:
vehicle speed signal
encoder plate position
brake pedal switch
digital transmission range (TR) sensor
ignition switch
Based on these inputs, the 4WD control module controls the shifts into 2WD, 4WD HIGH or 4WD LOW with the following outputs:
gearmotor (clockwise)
gearmotor (counterclockwise)
Inspection and Verification — Electronic Shift
Visually inspect for the following obvious signs of mechanical and electrical damage.
Visual Inspection Chart Mechanical Electrical
Axle shafts and universal joints
Driveshaft and universal joints
Fluid leaks
Matching tire size
Battery junction box (BJB) fuse 13 (20A)
Central junction box (CJB) fuse 10 (7.5A)
CJB fuse 11 (7.5A)
CJB fuse 35 (15A)
4WD control module
Damaged wiring harness
Mode select switch (MSS)
Shift motor/encoder assembly
Loose or corroded connector(s)
Circuitry
If the concern remains after the inspection, connect the scan tool to the data link connector (DLC) located beneath the instrument panel and select the vehicle to be tested from the scan tool menu. If the scan tool does not communicate with the vehicle:
check that the program card is correctly installed.
check the connections to the vehicle.
check the ignition switch position.
If the scan tool still does not communicate with the vehicle, refer to the scan tool manual.
Carry out the DATA LINK DIAGNOSTICS test. If the scan tool responds with:
CKT914, CKT915 or CKT70 = ALL ECUS NO RESP/NOT EQUIP, refer to Section 418-00.
NO RESP/NOT EQUIP for 4WD control module, go to Pinpoint Test B.
SYSTEM PASSED, retrieve and record the continuous diagnostic trouble codes (DTCs), erase the continuous DTCs and carry out the 4WD control module self-test.
If the DTCs retrieved are related to the concern, go to the 4WD Control Module Diagnostic Trouble Code (DTC) Index to continue diagnostics.
If no DTCs related to the concern are retrieved, carry out the Electronic Shift Function Test. Refer to Functional Test—Electronic Shift (Pinpoint Test A) in this section.
4WD Control Module Diagnostic Trouble Code (DTC) Index DTC Description Source Action
B1317 Battery Voltage High 4WD control module REFER to Section 414-00.
B1318 Battery Voltage Low 4WD control module REFER to Section 414-00.
B1342 ECU is Defective 4WD control module CLEAR the DTCs. REPEAT the 4WD control module self-test. If DTC B1342 is retrieved, INSTALL a new 4WD control module. REFER to Four-Wheel Drive (4WD) Control Module in this section. CLEAR the DTCs. REPEAT the self-test.
B1355 Ignition Run Circuit Failure 4WD control module GO to Pinpoint Test C.
B1483 Brake Pedal Input Circuit Failure 4WD control module GO to Pinpoint Test D.
B1485 Brake Pedal Input Battery Short 4WD control module GO to Pinpoint Test D.
B1555 Ignition Run/Start Circuit Failure 4WD control module GO to Pinpoint Test C.
C1728 Transfer Case Unable to Transition Between 2WD HIGH and 4WD HIGH 4WD control module CARRY OUT the electronic shift function test. REFER to Function Test — Electronic Shift (Pinpoint Test A) in this section.
C1729 Transfer Case Unable to Transition Between 4WD HIGH and 4WD LOW 4WD control module CARRY OUT the electronic shift function test. REFER to Function Test — Electronic Shift (Pinpoint Test A) in this section.
P0500 Vehicle Speed Sensor (VSS) Malfunction 4WD control module GO to Pinpoint Test D.
P1804 Transmission 4WD HIGH Indicator Circuit Failure 4WD control module REFER to Section 413-01.
P1806 Transmission 4WD HIGH Indicator Short Circuit to Battery 4WD control module REFER to Section 413-01.
P1808 Transmission 4WD LOW indicator Circuit Failure 4WD control module REFER to Section 413-01.
P1810 Transmission 4WD LOW indicator Short Circuit to Battery 4WD control module REFER to Section 413-01.
P1812 Transmission 4WD Mode Select Circuit Failure 4WD control module GO to Pinpoint Test C.
P1815 Transmission 4WD Mode Select Short Circuit to Ground 4WD control module GO to Pinpoint Test C.
P1816 Transmission Neutral Safety Switch Circuit Failure 4WD control module GO to Pinpoint Test D.
P1819 Transmission Neutral Safety Switch Short Circuit to Ground 4WD control module GO to Pinpoint Test D.
P1849 Transmission Transfer Case Contact Plate A Short Circuit To Ground 4WD control module GO to Pinpoint Test C.
P1853 Transmission Transfer Case Contact Plate B Short Circuit To Ground 4WD control module GO to Pinpoint Test C.
P1857 Transmission Transfer Case Contact Plate C Short Circuit To Ground 4WD control module GO to Pinpoint Test C.
P1861 Transmission Transfer Case Contact Plate D Short Circuit To Ground 4WD control module GO to Pinpoint Test C.
P1867 Transmission Transfer Case Contact Plate General Circuit Failure 4WD control module GO to Pinpoint Test C.
P1891 Transmission Transfer Case Contact Plate Ground Return Open Circuit 4WD control module GO to Pinpoint Test C.
Functional Test — Electronic Shift
PINPOINT TEST A: ELECTRONIC SHIFT FUNCTIONAL TEST
CAUTION: The function test must be carried out on a hard surface in a vacant area without traffic.
CONDITIONS DETAILS/RESULTS/ACTIONS
A1 CHECK INDICATOR PROVE-OUT
Start the vehicle while observing the 4WD indicators for prove-out.
Did the indicators prove out?
Yes
GO to A3.
No
GO to A2.
A2 CHECK FOUR-WHEEL DRIVE (4WD) CONTROL MODULE COMMUNICATION
Scan Tool
Retrieve 4WD control module self-test DTCs.
Did the 4WD control module respond?
Yes
REPAIR the instrument cluster as necessary. REFER to Section 413-01.
No
GO to Pinpoint Test B.
A3 CHECK FOR 2WD INDICATED
Start the vehicle and allow to idle.
Apply the brake pedal and hold.
Shift the transmission to NEUTRAL.
Turn the mode select switch (MSS) to 2WD while holding the shift conditions.
Observe the 4WD HIGH and 4WD LOW indicators.
Are both indicators off?
Yes
GO to A5.
No
GO to A4.
A4 CHECK FOR THE PRESENCE OF 4WD
Shift the transmission to REVERSE and back the vehicle up 3.0 meters (10 feet) to relieve driveline windup.
Drive the vehicle forward for 3.0 meters (10 feet) and stop.
Press the brake pedal and hold.
Shift the transmission to NEUTRAL. Hold the shift conditions for 20 seconds.
Execute tight turns on a hard surface.
Check for the presence of driveline windup and tire scuff.
Is driveline windup and tire scuff present?
Yes
RETRIEVE 4WD control module self-test DTCs. If a self-test DTC related to the concern is retrieved, REFER to the 4WD Control Module Diagnostic Trouble Code (DTC) Index. If no DTC is retrieved, REFER to Section 308-07B and REPAIR the transfer case as necessary.
No
If the 4WD HIGH indicator is ON, REFER to the Symptom chart in Section 413-01to continue diagnosis. If the 4WD LOW indicator is ON, REFER to the Symptom chart in Section 413-01 to continue diagnosis.
A5 VERIFY SHIFT TO 4WD HIGH
Turn the mode select switch (MSS) to 4X4 HIGH.
Listen for shift motor operation.
Wait for 20 seconds after MSS is turned to 4X4 HIGH. (The system will use up to five cycles of shift attempts trying to engage 4WD HIGH.)
Is the 4WD HIGH indicator ON?
Yes
GO to A7.
No
GO to A6.
A6 ATTEMPT MECHANICAL ASSIST ENGAGEMENT
Drive the vehicle above 8 km/h (5 mph) for at least 20 seconds.
Stop the vehicle.
Observe the 4WD HIGH indicator.
Yes
GO to A7.
No
RETRIEVE 4WD control module self-test DTCs. If a self-test DTC related to the concern is retrieved, REFER to the 4WD Control Module Diagnostic Trouble Code (DTC) Index. If no DTC related to the concern is retrieved, GO to Pinpoint Test C.
A7 CHECK FOR MECHANICAL ENGAGEMENT OF 4WD HIGH
Drive the vehicle for two minutes above 16 km/h (10 mph).
Yes
GO to A8.
No
4WD HIGH did not mechanically engage. RETRIEVE 4WD control module self-test DTCs. If a self-test DTC related to the concern is retrieved, REFER to the 4WD Control Module Diagnostic Trouble Code (DTC) Index. If no DTC related to the concern is retrieved, GO to Pinpoint Test C.
A8 CHECK FOR CORRECT INDICATOR OPERATION ON 4WD LOW ENGAGEMENT
While driving the vehicle forward above 8 km/h (5 mph), turn the MSS to 4X4 LOW while observing the indicators for five seconds.
Turn the MSS to 4X4 HIGH.
Stop the vehicle and apply the parking brake.
Shift the transmission to PARK and release the brake pedal.
Did the 4WD LOW indicator stay off?
Yes
GO to A9.
No
RETRIEVE 4WD control module self-test DTCs. If a self-test DTC related to the concern is retrieved, REFER to the 4WD Control Module Diagnostic Trouble Code (DTC) Index. If no DTC related to the concern is retrieved, GO to Pinpoint Test D.
A9 CHECK THE LOW RANGE INDICATOR ON IN ERROR
Turn the MSS to 4X4 LOW.
Apply and hold the brake pedal.
Is the 4WD LOW indicator OFF?
Yes
GO to A10.
No
A10 CHECK THE LOW RANGE INDICATOR FOR ON IN 4X4 LOW
Hold the shift conditions for 20 seconds. (The system will use up to five cycles of shift attempts trying to engage 4X4 LOW.)
Is the 4WD LOW indicator ON?
Yes
GO to A12.
No
GO to A11.
A11 ATTEMPT MECHANICAL ASSIST OF 4WD LOW ENGAGEMENT
CAUTION: Make sure there is a clear area behind the vehicle before backing up.
Shift the transmission to REVERSE and back the vehicle up 3.0 meters (10 feet) to relieve driveline windup and stop.
Observe the 4WD LOW indicator.
Yes
GO to A12.
No
A12 CHECK FOR MECHANICAL ENGAGEMENT OF 4WD LOW
NOTE: Driveline windup and tire scuff is present in both 4WD HIGH and 4WD LOW. However, vehicle speed is severely limited in 4WD LOW.
Check for the presence of driveline windup, tire scuff and reduced vehicle speed.
Is driveline windup, tire scuff and reduced speed present?
Yes
GO to A13.
No
4X4 LOW did not mechanically engage. RETRIEVE 4WD control module self-test DTCs. If a self-test DTC related to the concern is retrieved, REFER to the 4WD Control Module Diagnostic Trouble Code (DTC) Index. If no DTC related to the concern is retrieved, GO to Pinpoint Test D.
A13 CHECK FOR CORRECT INDICATOR OPERATION ON 4WD LOW DISENGAGEMENT
While driving the vehicle forward above 8 km/h (5 mph), turn the MSS to 4X4 HIGH while observing the indicators.
Yes
GO to A14.
No
A14 CHECK THE 4WD LOW INDICATOR
Yes
GO to A15.
No
A15 CHECK FOR 4WD LOW INDICATOR OFF IN 4WD HIGH
Press and hold the brake pedal.
Hold the shift conditions for 20 seconds. (The system will use up to five cycles of shift attempts trying to engage 4WD HIGH.)
Yes
GO to A17.
No
GO to A16.
A16 ATTEMPT MECHANICAL ASSIST OF 4WD LOW DISENGAGEMENT
Drive the vehicle forward above 8 km/h (5 mph) for at least five seconds.
Stop the vehicle.
Yes
GO to A17.
No
A17 CHECK FOR MECHANICAL 4WD LOW DISENGAGEMENT AND 4WD HIGH ENGAGEMENT
Apply the brake.
Stop the vehicle.
Drive the vehicle forward and execute tight turns on a hard surface.
Verify the presence of driveline windup and tire scuff. Also verify the increased vehicle speed from when 4WD LOW was engaged.
Did 4WD HIGH engage and the vehicle speed increase?
Yes
GO to A18.
No
4WD LOW is mechanically bound or locked. REPAIR the transfer case as necessary. REFER to Section 308-07B.
A18 CHECK THE 4WD HIGH TO 2WD SHIFT
Stop the vehicle.
Turn the MSS to 2WD and wait 20 seconds.
Is the 4WD HIGH indicator OFF?
Yes
GO to A20.
No
GO to A19.
A19 ATTEMPT MECHANICAL ASSIST OF 4WD HIGH DISENGAGEMENT
Drive the vehicle forward above 8 km/h (5 mph) for at least 20 seconds.
Stop the vehicle.
Yes
GO to A20.
No
A20 VERIFY THE TRANSFER CASE MECHANICALLY DISENGAGED
Apply the parking brake.
Rotate the front drive shaft.
Does the front drive shaft turn?
Yes
The transfer case is operating correctly. INSTRUCT the customer on correct system operation.
No
The transfer case did not disengage from 4WD HIGH. REPAIR the transfer case as necessary. REFER to Section 308-07B.
Symptom Chart — Electronic Shift
Symptom Chart Condition Possible Sources Action
No communication with the four-wheel drive (4WD) control module
Four-wheel drive (4WD) control module.
Central Junction Box (CJB).
CJB fuse 35 (15A).
CJB fuse 10 (7.5A).
Circuitry.
The vehicle does not shift between 2WD and 4WD modes correctly
Battery junction box (BJB) fuse 13 (20A).
Mode select switch (MSS).
Contact plate A, B, C, or D.
Shift motor encoder assembly.
Circuitry.
Transfer case mechanism.
The vehicle does not shift between 4WD HIGH and 4WD LOW modes correctly
Neutral safety switch.
Brake pedal position (BPP) switch.
Transfer case.
Digital transmission range (TR) sensor.
Circuitry.
The 4WD HIGH indicator is always on—four-wheel drive system operates correctly
Circuitry.
Instrument cluster.
REFER to the symptom chart in Section 413-01to continue diagnosis.
The 4WD LOW indicator is always on
Powertrain control module (PCM).
Circuitry.
Instrument cluster.
Pinpoint Tests — Electronic Shift
PINPOINT TEST B: NO COMMUNICATION WITH THE FOUR-WHEEL DRIVE (4WD) CONTROL MODULE
B1 CHECK POWER TO 4WD CONTROL MODULE
4WD Control Module C281a
4WD Control Module C281b
Measure the voltage between 4WD control module C281a, pin 1, circuit 931 (OG) and ground; and between 4WD control module C281a, pin 2, circuit 704 (DG/LG) and ground.
Are both voltage measurements greater than 10 volts?
Yes
GO to B2.
No
REPAIR the power supply as necessary. TEST the system for normal operation.
B2 CHECK 4WD CONTROL MODULE GROUND CIRCUIT
Measure the resistance between 4WD control module C281a pin 7, circuit 57 (BK), harness side and ground; and between 4WD control module C281b pin 2, circuit 570 (BK/WH), harness side and ground.
Are both resistance less than 5 ohms?
Yes
REFER to Section 418-00.
No
REPAIR the circuit. TEST the system for normal operation.
PINPOINT TEST C: THE VEHICLE DOES NOT SHIFT BETWEEN 2WD AND 4WD MODES CORRECTLY
C1 CHECK FOUR-WHEEL DRIVE (4WD) CONTROL MODULE POWER AND GROUND
CHECK previous tests performed.
Was Pinpoint Test B performed?
Yes
GO to C2.
No
C2 REVIEW THE DIAGNOSTIC TROUBLE CODES (DTCS)
Using the recorded results from the 4WD Control Module Self-Test:
Are any DTCs retrieved?
Yes
If DTC B1355 or DTC B1555is retrieved GO to C16 .
If DTC P1812 or DTC P1815 is retrieved GO to C3 .
If DTC P1849, DTC P1853, DTC P1857, P1861, DTC P1867 or DTC P1891 is retrieved GO to C10 .
No
GO to C3.
C3 CHECK THE MODE SELECT SWITCH (MSS) — MONITOR THE 4WD CONTROL MODULE PID 4WD_SW
Monitor the 4WD control module PID 4WD_SW while cycling the MSS through 2WD, 4WD HIGH and 4WD LOW.
Do the 4WD control module PID values agree with the MSS positions?
Yes
GO to C5.
No
GO to C4.
C4 CHECK THE MSS — ALL POSITIONS
MSS C284
Measure the resistance between MSS C284 pin 2, component side and pin 3, component side. Refer to the following chart:
MSS Position Resistance
2WD 3,705-4,095 Ohms
4WD HIGH 1,045-1,155 Ohms
4X4 LOW 342-378 Ohms
Are the resistances within the specified values?
Yes
GO to C5.
No
INSTALL a new MSS. REFER to Mode Select Switch (MSS) in this section. CLEAR the DTCs. REPEAT the self-test.
C5 CHECK CIRCUIT 435 (YE/BK) FOR A SHORT TO VOLTAGE
Measure the voltage between 4WD control module C281b pin 1, circuit 435 (YE/BK), harness side and ground.
Is any voltage present?
Yes
REPAIR the circuit. CLEAR the DTCs. REPEAT the self-test.
No
GO to C6.
C6 CHECK CIRCUIT 435 (YE/BK) FOR AN OPEN
Measure the resistance between MSS C284 pin 3, circuit 435 (YE/BK), harness side and 4WD control module C281b, pin 1, circuit 435 (YE/BK), harness side.
Is the resistance less than 5 ohms?
Yes
GO to C7.
No
C7 CHECK CIRCUIT 465 (WH/LB) FOR A SHORT TO VOLTAGE
Measure the voltage between 4WD control module C281a pin 5, circuit 465 (WH/LB), harness side and ground.
Yes
No
GO to C8.
C8 CHECK CIRCUIT 465 (WH/LB) FOR A SHORT TO GROUND
Measure the resistance between 4WD control module C281a pin 5, circuit 465 (WH/LB), harness side and ground.
Is the resistance greater than 10,000 ohms?
Yes
GO to C9.
No
C9 CHECK CIRCUIT 465 (WH/LB) FOR AN OPEN
Measure the resistance between MSS C284 pin 2, circuit 465 (WH/LB), harness side and 4WD control module C281a pin 5, circuit 465 (WH/LB), harness side.
Yes
GO to C10.
No
C10 CHECK CIRCUIT 762 (YE/WH), CIRCUIT 763 (OG/WH), CIRCUIT 764 (BN/WH), CIRCUIT 770 (WH), AND CIRCUIT 771 (VT/YE) FOR A SHORT TO VOLTAGE
Measure the voltage between the following circuits at the 4WD control module connector pins and ground.
Circuit 4WD Control Module Connector and Pins
762 (YEWH) C281b pin 4
763 (OG/WH) C281b pin 13
764 (BN/WH) C281b pin 7
770 (WH) C281a pin 15
771 (VT/YE) C281a pin 11
Yes
REPAIR the circuit(s) in question. CLEAR the DTCs. REPEAT the self-test.
No
GO to C11.
C11 CHECK CIRCUIT 762 (YE/WH), CIRCUIT 763 (OG/WH), CIRCUIT 764 (BN/WH), CIRCUIT 770 (WH), AND CIRCUIT 771 (VT/YE) FOR A SHORT TO GROUND
Gearmotor Encoder C350
Measure the resistance between the following circuits at the 4WD control module connector pins and ground.
Are the resistances all over 10,000 ohms?
Yes
GO to C12.
No
C12 CHECK CIRCUIT 762 (YE/WH) FOR OPEN
Measure the resistance between gearmotor encoder C350 pin 6, circuit 762 (YE/WH), harness side and 4WD control module C281b pin 4, circuit 762 (YE/WH), harness side.
Yes
GO to C13.
No
C13 CHECK CIRCUIT 763 (OG/WH), 764 (BN/WH), CIRCUIT 770 (WH), AND CIRCUIT 771 (VT/YE) FOR AN OPEN
Measure the resistance of the following circuits at the 4WD control module connector pins and gearmotor encoder connector pins shown.
Circuit 4WD Control Module Connector and Pins Gearmotor Encoder Connector and Pins
763 (OG/WH) C281b pin 13 C350 pin 3
764 (BN/WH) 281b pin 7 C350 pin 2
770 (WH) C281a pin 15 C350 pin 1
771 (VT/YE) C281a pin 11 C350 pin 5
Are all the resistances less than 5 ohms?
Yes
GO to C14.
No
REPAIR the circuit or circuit(s) in question. CLEAR the DTCs. REPEAT the self-test.
C14 CHECK CIRCUIT 777 (YE) AND CIRCUIT 778 (OG) FOR A SHORT TO VOLTAGE
Measure the voltage between 4WD control module C281a pin 17, circuit 777 (YE), harness side and ground; and between 4WD control module C281a pin 8, circuit 778 (OG), harness side and ground.
Yes
REPAIR the circuit(s). CLEAR the DTCs. REPEAT the self-test.
No
GO to C15.
C15 CHECK CIRCUIT 777 (YE) AND CIRCUIT 778 (OG) FOR AN OPEN
Measure the resistance between 4WD control module C281a pin 17, circuit 777 (YE), harness side and gearmotor encoder C350, pin 4, circuit 777 (YE), harness side; and measure the resistance between 4WD control module C281a pin 8, circuit 778 (OG), harness side and gearmotor encoder C350 pin 7, circuit 778 (OG), harness side.
Are the resistances less than 5 ohms?
Yes
GO to C16.
No
REPAIR the suspect circuit. CLEAR the DTCs. REPEAT the self-test.
C16 CHECK CIRCUIT 777 (YE) AND CIRCUIT 778 (OG) FOR A SHORT TO GROUND
Measure the resistance between 4WD control module C281a pin 17, circuit 777 (YE), harness side; and ground and between 4WD control module C281a pin 8, circuit 778 (OG), harness side and ground.
Are the resistances more than 10,000 ohms?
Yes
GO to C17.
No
C17 CHECK CIRCUIT 640 (RD/YE), CIRCUIT 1003 (GY/YE) AND CIRCUIT 704 (DG/LG) FOR VOLTAGE
Measure the voltage between 4WD control module C281b pin 6, circuit 783 (GY), harness side and ground; and between 4WD control module C281a pin 9, circuit 1003 (GY/YE), harness side and ground; and between 4WD control module C281a pin 2, circuit 704 (DG/LG), harness side and ground.
Are the voltages all over 10 volts?
Yes
GO to C18.
No
REPAIR the supply circuit. CLEAR the DTCs. REPEAT the self-test.
C18 CHECK CIRCUIT 931 (OG) FOR VOLTAGE
Measure the voltage between 4WD control module C281a pin 1, circuit 931 (OG), harness side and ground.
Is the voltage between 9 and 16 volts?
Yes
GO to C19.
No
TEST the charging system. REFER to Section 414-00.
C19 CHECK FOR CORRECT 4WD CONTROL MODULE OPERATION
Disconnect all 4WD control module connectors (C281a, C281b) and the gearmotor encoder connector (C350).
Check for:
corrosion
pushed-out pins
Connect all 4WD control module connectors and the gearmotor encoder connector making sure they seat correctly.
Operate the system and verify the concern is still present.
Is the concern still present?
Yes
GO to C20.
No
The system is operating correctly at this time. Concern may have been caused by a loose or corroded connector. CLEAR the DTCs. REPEAT the self-test.
C20 CHECK THE CONTACT PLATE ENCODER SWITCH
Monitor mode select switch (MSS) PIDs 2WD and 4WD HIGH.
Monitor contact plate PIDs PLATE_A, PLATE_B, PLATE_C and PLATE_D.
Cycle the MSS to 2WD and 4WD HIGH two times.
NOTE: Contact plate PIDs can only be read for approximately two seconds. To continue reading PIDs, cycle the MSS again.
Compare the contact plate PID values for each shift position selected by the MSS.
Plate PID MSS PID 2WD MSS PID 4HIGH
PLATE_A CLOSED OPEN
PLATE_B OPEN CLOSED
PLATE_C CLOSED CLOSED
PLATE_D CLOSED OPEN
Do the contact plate PID values agree with the MSS switch PIDs?
Yes
GO to C21.
No
INSTALL a new gearmotor encoder assembly. REFER to Gearmotor Encoder Assembly in this section. CLEAR the DTCs. REPEAT the self-test. If still inoperative, INSTALL a new 4WD control module. REFER to Four-Wheel Drive (4WD) Control Module in this section.
C21 CHECK THE TRANSFER CASE
Release the parking brake.
Using a wrench, manually shift the transfer case sector shaft to the full clockwise (2WD) direction while turning the rear driveshaft.
Engage the parking brake.
Rotate the front driveshaft.
Does the front driveshaft turn?
Yes
GO to C22.
No
REPAIR the transfer case. REFER to Section 308-07B. TEST the system for normal operation.
C22 CHECK THE SECTOR SHAFT TURNING EFFORT
NOTE: The transfer case has three detented shift positions. The full clockwise position is 2WD, the next position is 4WD HIGH, and the full counterclockwise position is 4WD LOW. Normal operation should not take more than 45 Nm (33 lb-ft) to manually shift the transfer case.
Using a torque wrench, manually shift the transfer case sector shaft in a counterclockwise direction to the 4WD HIGH detent position while rotating the rear driveshaft.
Did the torque required to shift exceed 45 Nm (33 lb-ft)?
Yes
REPAIR the transfer case as necessary. REFER to Section 308-07B. TEST the system for normal operation.
No
GO to C23.
C23 CHECK THE TRANSFER CASE SHIFT TO 4WD HIGH AND 4WD LOW
Does the front driveshaft rotate?
Yes
No
INSTALL a new gearmotor encoder assembly. REFER to Gearmotor Encoder Assembly in this section. CLEAR the DTCs. REPEAT the self-test. If still inoperative, REPLACE the 4WD control module. REFER to Four-Wheel Drive (4WD) Control Module in this section.
PINPOINT TEST D: THE VEHICLE DOES NOT SHIFT BETWEEN 4WD HIGH AND 4WD LOW MODES CORRECTLY
D1 REVIEW THE FOUR-WHEEL DRIVE (4WD) CONTROL MODULE DIAGNOSTIC TROUBLE CODES (DTCs)
Using the recorded results from the 4WD control module Self-Test:
Yes
If DTC P1816 is retrieved GO to D3 .
If DTC P1819 is retrieved GO to D4 .
If DTC B1483 or DTC B1485 is retrieved GO to D8 .
If DTC P0500 is retrieved GO to D13 .
No
GO to D2.
D2 VERIFY THE FUNCTION TEST HAS BEEN CARRIED OUT
Check the previous diagnostic procedure.
Was the electronic shift function test carried out?
Yes
GO to D3.
No
CARRY OUT the electronic shift function test. REFER to Functional Test — Electronic Shift (Pinpoint Test A) in this section.
D3 CHECK THE DIGITAL TRANSMISSION RANGE SENSOR PID NTRL_SW
Monitor 4WD control module PID NTRL_SW.
Place the gear shift lever in NEUTRAL.
Verify 4WD control module PID reads NTRL.
Shift the gear lever through all positions while monitoring 4WD control module PID NTRL_SW.
Does the 4WD control module PID NTRL_SW read NTRL only for the neutral position?
Yes
GO to D8.
No
GO to D4.
D4 CHECK CIRCUIT 463 (RD/WH) FOR A SHORT TO GROUND
Place the gearshift lever in any position except neutral.
Measure the resistance between 4WD control module C281a pin 16, circuit 463 (RD/WH, harness side and ground.
Is the resistance more than 10,000 ohms?
Yes
GO to D5.
No
REPAIR the circuit. SHIFT the gear lever between NEUTRAL and PARK twice. CLEAR the DTCs. REPEAT the self-test.
D5 CHECK CIRCUIT 463 (RD/WH) FOR A SHORT TO VOLTAGE
Measure the voltage between 4WD control module C281a pin 16, circuit 463 (RD/WH), harness side and ground.
Yes
GO to D7.
No
GO to D6.
D6 CHECK TRANSMISSION RANGE (TR) SENSOR CIRCUIT 463 (RD/WH) FOR AN OPEN
TR Sensor C167
Measure the resistance between 4WD control module C281a pin 16, circuit 463 (RD/WH), harness side and TR sensor C167 pin 8, circuit 463 (RD/WH), harness side.
Yes
GO to D8.
No
D7 CHECK CIRCUIT 463 (RD/WH) FOR A SHORT TO VOLTAGE
Is there voltage present?
Yes
REPAIR the circuit. SHIFT the gear lever between NEUTRAL and PARK twice. CLEAR the DTCs. REAPEAT the self-test.
No
INSTALL a new TR sensor. REFER to Section 307-01. SHIFT the gear lever between NEUTRAL and PARK twice. CLEAR the DTCs. REPEAT the self-test.
D8 CHECK BRAKE PEDAL POSITION (BPP) SWITCH 4WD CONTROL MODULE PID
Press the brake pedal.
Monitor 4WD control module PID BOO.
Does the PID value reflect the vehicle condition?
Yes
GO to D13.
No
GO to D9.
D9 CHECK CIRCUIT 810 (RD/LG) FOR A SHORT TO VOLTAGE
Measure the voltage between 4WD control module C281a pin 12, circuit 810 (RD/LG), harness side and ground.
Is there any voltage present?
Yes
REPAIR the circuit. PRESS the brake pedal twice. CLEAR the DTCs. REPEAT the self-test.
No
GO to D10.
D10 CHECK CIRCUIT 810 (RD/LG) FOR A SHORT TO GROUND
Measure the resistance between 4WD control module C281a pin 12, circuit 810 (RD/LG), harness side and ground.
Yes
GO to D11.
No
D11 CHECK CIRCUIT 810 (RD/LG) FOR VOLTAGE
Is the voltage at least 10 volts?
Yes
GO to D12.
No
D12 CHECK CIRCUIT 810 (RD/LG) FOR AN OPEN
BPP C278
Measure the resistance between 4WD control module C281a pin 12, circuit 810 (RD/LG), harness side and BPP switch C278 pin 2, circuit 810 (RD/LG), harness side.
Yes
GO to D13.
No
D13 CHECK THE SPEEDOMETER
BPP C278
TR Sensor C167
Monitor the speedometer.
Monitor 4WD control module PID VSS2 while driving the vehicle 0 to 88.5 km/h (55 mph) at a steady rate.
Does the 4WD control module PID VSS2 agree with the speedometer?
Yes
GO to D15.
No
GO to D14.
D14 CHECK POWERTRAIN CONTROL MODULE (PCM) CIRCUIT 679 (GY/BK) FOR AN OPEN
PCM C175
Measure the resistance between 4WD control module 281b pin 12, circuit 679 (GY/BK), harness side and PCM C175, pin 58, circuit 679 (GY/BK), harness side.
Yes
GO to D15.
No
REPAIR the circuit. DRIVE the vehicle to a speed of 40 mph (64 km/h). CLEAR the DTCs. REPEAT the self-test.
D15 CHECK THE MODE SELECT SWITCH (MSS) — MONITOR THE 4WD CONTROL MODULE PID 4WD_SW
PCM C175
Yes
GO to D17.
No
GO to D16.
D16 CHECK THE MSS — ALL POSITIONS
MSS C284
Measure the resistance between MSS C284, pin 2, component side and pin 3, component side. Refer to the following chart:
4WD LOW 342-378 Ohms
Yes
GO to D17.
No
D17 CHECK FOR CORRECT 4WD CONTROL MODULE OPERATION
Check for:
corrosion
pushed-out pins
Yes
GO to D18.
No
D18 CHECK THE CONTACT PLATE ENCODER SWITCH
Monitor mode select switch (MSS) PIDs 2WD and 4WD LOW.
NOTE: The contact plate PIDs can only be read for approximately two seconds. To continue reading, cycle the MSS again.
Cycle the MSS to 2WD and 4X4 LOW two times.
Plate PID MSS PID 2WD MSS PID 4LOW
PLATE_A CLOSED OPEN
PLATE_B OPEN CLOSED
PLATE_C CLOSED OPEN
PLATE_D CLOSED CLOSED
Do the contact plate PID values agree with the MSS PIDs?
Yes
GO to D25.
No
GO to D19.
D19 CHECK CIRCUIT 762 (YE/WH), CIRCUIT 763 (OG/WH), CIRCUIT 764 (BN/WH), CIRCUIT 770 (WH), AND CIRCUIT 771 (VT/YE) FOR A SHORT TO VOLTAGE
Yes
No
GO to D20.
D20 CHECK CIRCUIT 762 (YE/WH), CIRCUIT 763 (OG/WH), CIRCUIT 764 (BN/WH), CIRCUIT 770 (WH), AND CIRCUIT 771 (VT/YE) FOR A SHORT TO GROUND
Yes
GO to D21.
No
D21 CHECK CIRCUIT 762 (YE/WH) FOR AN OPEN
Yes
GO to D22.
No
D22 CHECK CIRCUIT 763 (OG/WH), 764 (BN/WH), CIRCUIT 770 (WH), AND CIRCUIT 771 (VT/YE) FOR AN OPEN
Yes
GO to D23.
No
D23 CHECK CIRCUIT 777 (YE) AND CIRCUIT 778 (OG) FOR A SHORT TO VOLTAGE
Yes
No
GO to D24.
D24 CHECK CIRCUIT 777 (YE) AND CIRCUIT 778 (OG) FOR AN OPEN
Measure the resistance between 4WD control module C281a pin 17, circuit 777 (YE), harness side and gearmotor encoder C350 pin 4, circuit 777 (YE), harness side; and between 4WD control module C281a pin 8, circuit 778 (OG), harness side and gearmotor encoder C350 pin 7, circuit 778 (OG), harness side.
Yes
GO to D25.
No
D25 CHECK CIRCUIT 777 (YE) AND CIRCUIT 778 (OG) FOR A SHORT TO GROUND
Yes
GO to D26.
No
D26 CHECK THE TRANSFER CASE
Yes
GO to D27.
No
D27 CHECK THE SECTOR SHAFT TURNING EFFORT
Yes
No
GO to D28.
D28 CHECK THE TRANSFER CASE SHIFT TO 4WD HIGH AND 4WD LOW
Yes
No
INSTALL a new gearmotor encoder assembly. REFER to Gearmotor Encoder Assembly in this section. CLEAR the DTCs. REPEAT the self-test. If still inoperative, INSTALL a new 4WD control module. REFER to Four-Wheel Drive (4WD) Control Module in this section. CLEAR the DTCs. REPEAT the self-test.
