02 4.0 pulse damper replacement | Ford Explorer Forums
Stainlessguy
Princeton, MN
2003 Ranger FX4
I’ve come to the conclusion the the diaphragm is bad on my pulse damper and it needs to be replaced or deleted. If it can be deleted/bypassed I’m open to suggestions on how to do that. Otherwise, do I need to remove the intake to replace the pulse damper or can it be done without getting that involved?
It’s been hard starting for a long time now because fuel pressure bleeds out of the system. After sitting about 30-40 minutes it becomes hard to start. I recently discovered that fuel is bleeding back into the vacuum system and being stored in the vacuum ball/reservoir.
Any tips on how to replace or delete the damper would be greatly appreciated. Thank you for your time.
