NEWFS02X
- June 25, 2006
- Manitoba,Canada
- 2002 E/B 4x4
Hello. I have an o2 E/B with the 4L SOHC. I'm assuming that it has the 5R55E tranny. I've had the vehicle for a year now and have noticed a couple of issues with the tranny.
1. Sometimes, not all the time, when shifting the vehicle into Drive from Park there is a split hesitation and the engine 'jumps'. Just as if you held the brake with one foot and stabbed the throttle with the other. In reverse it rarely does it but has done it on occasion.
2. Most important problem: Several times while pulling onto the street the truck accelerates normal in first and then when it hits 2nd the engine revs as if it just got bumped into neutral. I've manually pulled it down into the next gear and it has worked fine. Doesn't do it all the time-maybe 2-3 times a month.
Is this a VB issue or a solenoid?
No codes and I'm ready to do a trans service.
What issues in particular does the Sonnax kit correct?
Thank you........John
