DavidS
- February 24, 2005
- Kingsport, TN
- '02 Eddie Bauer
I've got a '02 Explorer EB 4.6L V8 and finally got around to changing the spark plugs after 150K miles (I know, I know). After pulling the left bank (from driver's position), I found that the back three of the plugs wells evidently had noticeable amounts of oil in them. This wasn't apparent until I removed the plugs which caused the plug socket and everything above the threads to be pretty well coated in dark motor oil. The electrode and ground portions of the plugs that are inside the heads were clean although somewhat eroded from the many, many miles on them. I started on the right hand bank and after pulling the front plug, it was clean just like the other side. I'm going to have to pull the intake hose section to be able to access the coils and plugs for the other three.
I also have another issue that I don't know if it's ignition-related or not. Often times in traffic stopped at a light in gear, it makes a chugging kind of sound, almost like a miss or something originating from what seems like the air intake. I've been under the hood when this starts up and it goes away immediately upon increasing the rpms of the engine. Any ideas folks? I've noticed the tachometer will wobble slightly when this is happening, which is quite regularly.
Does anyone have any idea what's going on with these? It has recently started using oil out of the blue (about 1/2 qt every 500 miles), but no leaks under it and no visible smoke. I first thought major issues but after seeing that the plugs business ends were okay, I was puzzled. Any comments would be appreciated. Thanks to all!
