'02 explorer low oil pressure sensor going off | Ford Explorer Forums
ep2256
Texas
Explorer marking low oil pressure sensor but when checked is fine. Also engine sounds like a rattle when turning on and rattle decreases a little after engine warms up. What could be wrong?
what do you mean by you checked it? you checked the oil level or the oil pressure? If all you did was check the oil level then you need to check the pressure. Oil doesnt do your engine any good sitting in the oil pan. You may have a failing or clogged oil pump. worst case scenario, you keep driving and sieze your engine.
