Ranger J.
- December 16, 2014
- 2002 ford explorer
Hi Folks,
I'm a former mechanic from various-make dealerships who is starting to get back into the field again after a two-decade hiatus, mainly for the purpose of servicing my own vehicles, because, frankly, I'm a little apprehensive about the apparent lack of diagnostic ability in the staff at my local Ford dealers.
Unfortunately, I've chosen to use a 2002 Explorer (the worst of the worst according to at least one website) to cut my teeth on. What's happening currently is that after I removed the hvac module to replace a mode door that had a broken lever, after getting the dash back together, the four wheel drive module died of natural causes, a diagnosis showed power/ground sources as they should be, and the new module cured the inactive dash selector switch. I think I'm missing the ground connection (G300) on the right A pillar because the instrument cluster goes through the "bulb test" mode and the odometer goes dark when the transmission is shifted into reverse and the "four wheel drive high" cluster indicator flashes ten times periodically. I'll get the ground condition diagnosed, as I more than likely caused it. My problem is that I can't find any information or chart that gives an accurate description of the self diagnostics behind the lamp operation (what code, if any, does the number of flashes indicate?)
My other question is, does anyone know if Ford sells any access to this information, as service manuals as I knew them are a thing of the past?
