gforceman
- April 7, 2003
- Virginia beach VA
- 2003 limited 4.6 V8
i see the 02 and up have a 2 peice drive shaft with a plastic coller over the slip joint in the middle , when i push the center of the shaft up or down sidways it moves in all directions is this normal ? when i put the truck in reverse and hit or tap the gas i hear a crack noise in the center rear i checked the u joints and there tight . i only get play in that center slip joint in the driveshaft could that cause the crack noise i hear has anyone had problems with there driveshaft ?
