'02 explorer slow to go into drive and reverse | Page 2 | Ford Explorer Forums
Ok..I've made the plunge and purchased the solenoid pack on e-bay. Now I will venture into uncharted waters using Borland's wonderful instructions I found here at this link:
http://www.explorerforum.com/forums/showthread.php?t=164055&highlight=Solenoid+replacement
Since I only recently had the whole tranny flushed and refilled with Mercon V I should be able to utilize the majority of the ATF if I capture it properly(that will be the hard part working in confined space in my garage with no lift.
Left to purchase before I begin are a t-30 wrench, the NPT barb tool( I found lots of 1/8 x 27 NPT's in plastic form...will that work as opposed to the oem brass one that costs $20?). The goofs at AAMCO just stuck a hose up into the bottom of the pan and pumped in the ATF(Dextron btw which started my whole problem in the beggining I might add). Also some 1/4 hose and something to catch the draining fluid.
I have a question....in Borland's instructions he mentions:
"Draining ATF with 22mm wrench. Only about 4 qts drained". Is this a seperate drain plug on the 5r55w besides the one on the bottom of the pan....sure looks like it according to the picture?
Anyways......wish me luck and I sure hope I don't wind up getting it towed to garage to finish :-).
Thanks again,
Tim
According to the reply from the guy selling...
The solinoid pack in this auction is the correct one for an 03 explorer. the 4L2Z-7G391-AA is for 04 and up transmissions.The 2 parts are not interchangable. You can look at the VIN sticker inside your drivers door jamb and if your explorer is 03 it takes this solinoid if its 04 it takes the 4L2Z-7G391-AA
