PPro
- December 27, 2004
- Whitmore Lake, MI
- '02 Sport
Well its spring time again, and it's time for me to pay a little closer attention to my truck. Here are the current issues I have questions about:
Front end shake: In tight corners at very slow speeds I get a front end shake in my X. This happened in my '00 XLT I had, but I sold it recently after that. What causes this/how do I fix it?
Shocks & Struts: I'm getting a pretty nasty bump steer, and the ride is very rough. I know its a short wheelbase, but it seems worse than other 2 door X's I've riden in. Is there an easy way to "test" the shocks and struts to see if they need to be replaced?
Rear end sag: I'm trying to find some 4 door X leaf springs to add, or I may just cheap out and use some Autozone shackles on it. However, the driver side rear end seems to sit lower than the passenger side, could this be a shock/strut issue as well?
I just rolled over 60K on it, what things should I be inspecting at about this time? I bought it with like 50k on it and have used only 100% Amsoil Synthetic oil and thats about all the work I've done on it. Recommendations would be great, thanks.
