02 Sport Trac double din | Ford Explorer Forums
joshgfeller
So I am going to install the Pioneer AVH-3200BT into my ST soon. I am also going to do the backup camera add-on. Can someone tell me where I can hook into a backup circuit or reverse light wire to let the deck know when to kick over to the backup camera?
The backup lamp circuit is a black w/pink stripe wire that runs down the left side of the floor under the door sill plates. It also crosses the dash in the main harness to the central security module pin #12. This same harness is where the radio wiring comes out of so locating the wire in that harness would be the easiest/most convenient to tap into.
Dash Wiring
Security Module Pinout
Great thanks, so steps for the backup camera.
1. mount it the the rear of vehicle and give it a 12v power supply possibly from the tailights.
2. What wire do I connect from the stereo harness of the p3200? I will connect this wire to the black/pink wire on the vehicle to make the stereo kick over to the camera.
3. Connect the video connector from the camera to the back of the headunit and walah!
Only other thought, do they make a backup camera with a wireless transmitter that doesn't come with a monitor? This would be great so I wouldn't have to run the wire all the way from the camera. If not, how do you get the wire into the cab?
I have manuals & can do Ford wiring but I have NO idea about your stereo or camera wiring.
