02 Sporttrac Audio Question | Ford Explorer Forums
Black_Sport
Nashville, TN
'02 Sport Trac
My ST has an aftermarket/factory pioneer system, including the four pioneer speakers in the door and the 8 inch pioner sub under the rear driver side seat. I installed an aftermarket stereo and the sub wasn't acting right so I installed an aftermarket amplifier located right next to the factory, I just ran the sub to the new amp and left the old amp to power the front speakers, the rear speakers are ran off the radio.
Problem, after I installed the new amp and got everythign going the front left speaker makes a high pitched noise when the car is on. I thought it would be the new amp so I unhooked the power up at the battery and the hum still exists. The only speaker that does it is the front left.
I cut the sub wires from the old amp so it's not getting a feed, also I spliced into the amp turn on from the other amp. The Power cable is ran on the left side of the vehicle (same as speaker) and the RCAs are ran on the right side of the vehicle.
Any ideas?
