czersalad05
- April 9, 2011
- Seattle,WA
- 2002 XLS
ok so like 2 days ago i was heading to work and i was running late so instead of deciding to stop at the light i sped so i could make it on yellow, i probably went around 40mph+ and took a hard left, i made it but i heard a clunk and i kinda drifted a bit, after a while the back side of the vehicle was kind of shaking, i moved my left hand mirror si I could see the left rear wheel, i noticed it was spinning all crooked and wobbling as if the lug nuts were loose, so i pulled to the side of the road and took a look at all the tires, i noticed the rear passenger wheel was slightly slanted while the rear driver wheel was very slanted, and the lug nuts were tightly on. I continued driving slow and after a while the rear left door locked up and i was dragging it, so i reversed it a short stretch and continued driving. I continue driving it, every time i hear some metal scraping or the brakes making friction with the rim i just reverse it, I know I shouldn't continue like this but in the meanwhile i don't got transportation to work. After I drive for a while the rear drivers brake seems to be touching the rotor because it stinks every time i have my window open and i top at a stop light.
What might be the problem? I don't have much money right now to fix it, i just got my cellphone jacked along with my wallet at a gas station because i left the window down while i went inside to pay for gas, I have bad luck right now.
