Christobal
- July 23, 2007
- SoCal
- 93 XLT, 03, 2 wheel drive
Out of the blue I started it cold and it immediately sounds like chain slapping under there and the engine didn't want to run but did have some combustion.
I noticed no coolant when it first happened but when placed nose up instead of nose down where parked when it happened, 4-8 oz of coolant dropped from rear of engine. I would not think the chain issue would cause a simultaneous coolant expulsion. Coolant in since 3 months before it happened.
If rolled back from the water pump, which is original, Ive never had a water pump fail catastrophically on start up with no warning leading up.
if it was the chain, or chains, Ive read about noise leading up and just have not heard anything. I did notice what I would call a slight tendency to be harder to start at times, not consistent and slight, and I mean slight roughness here and there at idle.... no indication of power loss anywhere or roughness under load at any rpm.
I haven't taken a closer look since, curious what you all think. All that immediate noise and clatter immediately at start has me thinking the chain and tensioner weakness reared its ugly head. The coolant pushed out in combo has me puzzled.
I have read this is NOT an interference engine, but also have read it IS. Who has the fact(s) on this?
BTW this thing has had normal -30 weight Mobil 1 since about the third oil change and has operated in a relatively warm climate, so I doubt cold temp viscosity oiling issues over time.
Mobil 1 since 3rd oil change new and moderate to warm SoCal climate since new.
