03 crown vic motor swap underway....pt 2 conclusion | Ford Explorer Forums
03explorereb
cuba, missouri
06 explorer xlt
just completed this swap. i broke this into two threads, first one being the initial start of the swap and this one being the finish. holy crap. there is a world of difference in difficulty level between the 4.0 and the 4.6. let me tell you that extensions are your best friend on a 4.6. use them early and often. there are several differences between engines that i noted in the first thread that i will confirm here. let's first review what differences i initially noted, updated in red:
1- the most obvious, ex is aluminum block, crown vic is cast iron
2- intake and fuel delivery is different-intake looks same, tb is different
3- front cover does appear to be different, unconfirmed on whether or not this will work per my application-might have worked but relocating the ps pump closer to the oil filter might have caused a problem
4- oil pan is different. may or may not work. the cv's pan is a little deeper at the front towards the balancer leading me to believe that it will not work in a 4wd application-will not work without modification to the cv's oil pan. pickup tubes are different also. the ex's pan is notched to clear the front differential for 4x4 applications, although the cv's might work for 2wd apps.
5- flexplates cosmetically look different but cannot confirm whether or not the cv's will work in my application. the ex's looks a little more dished out than the cv's.-for the swap you must use the ex's.
6- manifolds are different. not really even close. i do like the higher perch point of the cv's on the passenger side to clearance for the motor mount nuts but i think it would be senseless to modify exhaust pipe for this perk.-confirmed
7- mount point of the a/c compressor is the same. confirmed
8- motor mounts are different but you probably already figured that out-confirmed
9- this particular cv engine used an external oil cooler so the filter boss is different from the ex, which it did not have an oil cooler. the angle of the filter comes forward at about 45 degrees on the ex whereas the cv's is more straight out from the boss. i think i need the one from the ex from the way it looks-confirmed
10- dipsticks are different also. ex uses a longer dipstick.-confirmed and the ex's must be used for the oil pan/manifold combo anyways
I will also tell you that the knock sensor situation for me consisted of using the lone sensor boss (the cv engine has one whereas the ex uses two mounting bosses on each side of the intake valley) for one sensor and using the remaining knock sensor for the back of the passenger side head. also the water pump was different for the cv and therefore had to be replaced with the one from the explorer.
here were the costs associated:
1-2003 explorer xlt 4x4 4.6 with spun rod bearings on 2,3,4,6,and 7:$2000
1-2003 crown vic police interceptor 4.6 engine with low mileage: $450
1-felpro intake gasket set-40.99
1-felpro oil filter adapter set-4.99
1-felpro exhaust gasket set-10.99
1-felpro one piece oil pan gasket-23.99
ass-load of cleaning supplies-bout 15.00
this was definitely not a direct bolt in but there is money to be saved by going this way instead of using the direct bolt in replacement engine from another explorer. due to not being able to find my scanner i cannot confirm timing activity but i will let you all know in the near future. so far i have no check engine light as of yet. i ran a block off for the egr and exhaust manifold because i broke the damn tube during removal. i hooked up the dpfe sensor but blocked the passages also. as of yet, no cel. also, the motor mounts for the ex use a 4 hole mount setup but there is no boss for the bottom corner bolt on both sides of the cv so i omitted one bolt on each side. no biggie. one other thing, you should use the coolant crossover tube from the explorer (the one under the intake) although the cv's looked like it would work. that's it other than a lot of friggin work to make it happen. looks right at home in there. thanks everybody for the input and once again, if you have any questions feel free to ask.
I'm considering this exact job. I'm wondering if you have any follow up info on the success or failure of the crown vic engine swap.
I have a feeling this job might be over my head, but if you had success thatd be very encouraging.
not over your head. Very easy and inexpensive swap alternative to the explorer engine. I have done several of these swaps. Follow the above thread to the letter and you should have no problems. Just make sure the engine you buy is the Romeo engine VIN W from about '99 up. The engine removal itself is a bit more difficult than a 4.0 due to the sheer size of the engine. Once you have both engines setting side by side it becomes obvious what you need to swap. A piece of advice: if you are replacing with an engine over 100,000 miles I would suggest a new intake while the engine is out. Most of the 4.6's develop cracks around the water jackets of the intake after that (some before 100000). You can find them on Amazon for 140 bucks or so. Hope this helps and good luck. Swap it out with confidence.
If you have any questions just post and I will get back to you....
Sorry, I know this is an old thread. Did you use The cv intake or the explorers? They do have different ports
Actually they should be the same unless the engine you have is the non pi engine. If I remember correctly you need to block off a water port at the rear passenger side of the intake. I have used both. Throttle body is different as well as the egr system. Check out amazon.com and mock an order up for an intake for both. Part numbers should be the same if I remember correctly.
It is a non pi engine and the heads have different ports.I can Block off the water port and will also have to block off the egr to make it work If I use the cv intake. I tried the ex intake first and it leaked. Neither intake is the best and will probably have to get a new one. Any suggestion on whether to use the cv non pi intake or the ex?
Crown Vics are body on frame...last car of its kind these days.
I would've just transplanted the Exploders body onto the Vic's frame.
Probably would've been easier...plus who has an exploder riding that low.
Google "hot rod garage crown hick"
I have a 2004 explorer 4.6 4x4 and I have the option to buy a 2011 CV engine, what kind of challenges am I in for?
Did you read the first post of this thread? It's pretty much all explained.
I really doubt it’d be easier. Swapping cabs is a tough job going from one vehicle to the same. Swapping a heavier truck can onto a car frame is doubtful to be easy.
I was lucky enough to get a used explorer 4.6 for 400. Have seen several cross the block at copart for under 600 with fees for the entire vehicle.
Yes I read both, but this swap was done with engines from the same year, I’m asking if the 2011 crown Vic engine would work in a 2004 explorer?
Gotcha. The only difference in the later CV engine is 09+ has a different cam sensor trigger gear on drivers head.
I did the cast iron crown vic 4.6 into a mercury mountaineer, before i seen your post and did all the parts swaps to make things fit my problem is that the oil pressure takes a full minute on first start up before it gets any pressure, replaced switch, checked and recheck wiring loom, added a mechanical gauge and crap, really no oil pressure on initial start up. I did try swapping out the oil filter to make sure that wasn't it, Ford filters always, no luck there. so i purchased a high pressure oil pump, replace the oil pickup tube o-ring, and pulled out a lot of hair. While i was into the oil pump i did replace all the timing components. very disappointing. engine was out of a low mileage pi crown vic. any ideas? My buddy at ford shop says just drive it til it drops and do it again. That is not for me. Engine makes no noises yet. But I'm afraid it will start if I keep it this way.
