Marcus Aurelius
- June 20, 2009
- Toms River, NJ
- 2001 XLT
I have a 2003 Ranger, 3.0L, Automatic, 2WD.
When I try to go into gear from park, it dosen't engage correctly. I move the lever on the column, let off the brake, and it dosne't move for a minute. When I change to ther gears or give it a little gas, it sometimes engages. It did it this morning and afternoon.
Sometimes it engages randomly while Im giving it some gas and the tires spin a little. Other times, when I get it moving and I press on the brake to stop, it stops rapidly with very little brake pressure.
I have had this problem before, and it turned out it was some relay/ computer thing that tells the trans what gear to go into. It apparently is very sensitive to water and probably got wet.
It worked fine when i got it replaced and the the parking brake gear lock wasn't engaging, so then i got that replaced. Now the first problem is happening again.
btw, it has also been raining alot and may have gotten wet again.
So, do I have to replace this thing again, after only a month? And is there a way to protect it from getting wet? because it seems like any puddle kills it.
