dorin18
- November 9, 2008
- Stratford, CT
- '98 XLT 4x4 '04 XLS AWD
I decided to return the Dorman balancer. I installed the one that was on the '98 engine.
All seems to be okay with the engine. Runs smooth and I have no codes stored.
What still bothers me:
it seems that there is a relay that turns ON for a few sec. from time to time and makes the engine/whole car shaking a little bit (like when the electric fan starts, but I don't have an electric fan...) The only thing that comes to mind is the AC... Can it start even if the vent is OFF?
I also have a noise on the right front wheel that is very similar to a worn axle or maybe worn wheel bearings. I changed the tires and the noise changed a little bit. I saw that the ball joint has a bit of movement and today I bought a new one. I'll replace it tomorrow (hopefully) and see what happens. Thursday the exp will get two new tires and a front alignment.
If this will not take the noise away...I will have to live with it, because I'm taking the car to Europe and Monday I have to deliver it to Newark (no time to make other repairs). Worst case scenario: I will get a hub assembly in the suitcase and I will install it there - in vacation...
I know this isn't the right thread for this question, but I'll ask anyway:
Does anybody know a cheap place to get a replacement ignition key in southern CT? The cheapest place I found asked $75 for cutting and programming their blank key. I was hoping that I can get it under $50...
Thanks again to all the people that helped me with answers!
