04 Power window problems. | Ford Explorer Forums
Silverghost
Ontario
2004 Ford Explorer Ltd
Have intermitant problems with power windows operating. At this point, all 4 doors are not working. Have checked with my meter & it appears that I have power to the drivers side door switch cluster.
welcome
hey bra!
check all of my post. I had the same problem and it was a broken wire in the door jam (black) if you can't find my posts let me know and i will give you the info to check to see if your wire is broke. good luck ah!
had the same problem...broken black wire in the driver side door jam
Intermitant Rear Window problem
I have an intermitant problem with the rear passenger window on my 2004 XLT too. Of course it never happens when I take it to the shop to have it checked out!:exp:
Thanks i have to check this out.
Welcome aboard!! :salute:
I had similar electrical issues with my '02 XLT. The dome lights would stay on until the battery saver feature turned them off, the accessory delay wasn't working, the driver side puddle light didn't work, the keypad on the door would set off the alarm when I pressed it, the door ajar light would flash and beep at highway speeds, the radio would shut off as soon as I turned the key off, the alarm would beep twice when I armed it. Recently all 4 windows stopped working. Most recently the driver door lock actuator stopped working.
A lot of electrical issues can be traced back to broken/damaged wire(s) in the boot between the body and the driver's door. I found 3 broken wires and repaired them. The thin black ground wire was broken and after repairing it all was back to normal. When the windows stopped working, I repaired the thick black ground wire and the windows now work like a champ. I had to repair the pink/black wire to fix the driver door lock actuator.
Here is the thread for removing the door panel: http://www.explorerforum.com/forums//showthread.php?t=303524
Here is a great thread for checking for broken/damaged wires, thanks to synyster for this awesome write-up: http://www.explorerforum.com/forums//showthread.php?t=270081
Unfortunately the pictures are no longer available in the above thread. IIRC, I believe I unwrapped the wires enough to gain access. When I have gone searching in there I had an idea of what wire I was looking for. I located the the wire I was looking for and gently tugged on that wire on the door side. The wire was pulled toward me and out of the harness. I then went inside the vehicle and gently tugged on the the wire I was looking for and was able to pull it inside the vehicle. I then spliced a length of wire to the 2 ends, completing the circuit. I then gently pulled the excess into the door.
Be sure to take your time when looking for broken/damaged wire(s). Check all the wires for breaks/damage. When you think you're done looking, look again, and again, and again. A bright flashlight can be very helpful.
Please keep us posted as feedback helps others reading this post looking for a fix to the same or similar issue!
Good luck getting it sorted!! :D:thumbsup:
wow! this was every good thanks!
You're welcome. Did you get it sorted? :dunno:
