04 SportTrac is home, had abs 4 2 code. | Ford Explorer Forums
SeekerLazarus
Central New York
04 4x4 SportTrac XLTPrem
I went to pick up the 04 Sport Trac from the dealer and had an ABS code 4 2. Had the dealer run the code as under the purchase warranty (90 day) and extended warranty 6 yr and 60,000 extended, I found out is was actually covered under the safety and restraint warranty (27,500miles). They replaced the front impact sensor and reset and tested the system and is aok now. Way to go FORD!.
