05 explorer door ajar problem | Ford Explorer Forums
Johnny5101
Convoy, ohio
05 ford explorer 4.6L
I am having an issue with my 05 explorer 4.6. All the lights are on and it says I have a door ajar. I have checked every one. Opened and reshut, even the hatch. Has anyone else had this proble. Or know how to fix this issue.
I did the turn ur key to the on position and find out which door doesn't charm. And the only door that actually charmed was the rear hatch. Doesn't make any sense.
BigRondo's post is what solved my "Door Ajar" Issue:
Welcome aboard!! :salute:
I had similar electrical issues with my '02 XLT. The dome lights would stay on until the battery saver feature turned them off, the accessory delay wasn't working, the driver side puddle light didn't work, the keypad on the door would set off the alarm when I pressed it, the door ajar light would flash and beep at highway speeds, the radio would shut off as soon as I turned the key off, the alarm would beep twice when I armed it. Recently all 4 windows stopped working. Most recently the driver door lock actuator stopped working.
A lot of electrical issues can be traced back to broken/damaged wire(s) in the boot between the body and the driver's door. I found 3 broken wires and repaired them. The thin black ground wire was broken and after repairing it all was back to normal. When the windows stopped working, I repaired the thick black ground wire and the windows now work like a champ. I had to repair the pink/black wire to fix the driver door lock actuator.
Here is the thread for removing the door panel: http://www.explorerforum.com/forums//showthread.php?t=303524
Here is a great thread for checking for broken/damaged wires, thanks to synyster for this awesome write-up: http://www.explorerforum.com/forums//showthread.php?t=270081
Be sure to take your time when looking for broken/damaged wire(s). Check all the wires for breaks/damage. When you think you're done looking, look again, and again, and again. A bright flashlight can be very helpful.
Hope this helps out. :biggthump
Please keep us posted as feedback helps others reading this post looking for a fix to the same or similar issue!
Thanks so much. I'll check this tonight after work. Greatly appreciated.
