'05 Explorer Radio Bezel Removal | Ford Explorer Forums
draggn
Tucson, AZ
2005 Explorer Eddie Bower
OK I have an '05 Eddie Bower Explorer and need to know how to remove the fake wood radio bezel. I picked up the 6 disc changer with MP3 to replace the early model non MP3 version mine came with but need to know how the bezel comes off. Any help will be appreciated.
I just pulled mine on an '02. If you can gently place a screwdriver under the bottom of the bezel and pry out, it should pop out. Then pull out and up(by hand if possible) and it should start poping off. It is attatched in six places.
Jared G.
I used a metal butterknife. A screwdriver has a better chance of making a small "dent" in the plastic.
when i poped mine off all i did was push the vents downward like you are tryn to heat up you cup holders, the i used my hands and placed them just in over the lip and pulled. it has worked every time. if you think your going to break it you wont it just takes some elbo grease. :thumbsup:
